| Message |
I concur with Xteam300TT I think you should check your timing by using a spark plug wire between the coil and the spark plug of #1 and utilize a normal timing light attached to said spark plug wire, if the timing is correct your problem lies elsewhere. If the timing is incorrect take the timing cover off of the driver's side and put #1 at TDC, make sure the marks line up- if the marks do line up your CAS is faulty OR your crank pulley was made incorrectly/the woodruff key is missing.
*disclaimer*: all that I say may be true or I may be completely wrong and I accept that.... please, it is your duty as another person on the internet to impolitely tell me how wrong I am :) "The dreaded 2nd windshiled wiper swipe when you turn it off its almost like tis showing you that it's boss, and it doesn't have to stop when you tell it to :("-College Boy (discussion on ptu relocation) "No good reason to put it there anyway. -Bernie (NoVA) False -vorpalZ False. -Bernie (NoVA) You're correct, there are 3 good reasons -vorpalZ False. -Bernie (NoVA) Wow, right again, just remembered another, make that 4 -vorpalZ" XD
